I am trying to debug by code in eclipse of Quartus 13.1. Usually to generate the elf, I set the run time parameter in the makefile using CFLAG in nios2command shell as below: --set CPPFLAGS -dparameter name where parameter name is the name of the macro parameter. However, in eclipse I am not able to set the same parameter. I tried to set the parameter from the symbols tab in project properties-> c/c++ general->path and symbols (screenshot attached with the thread).
But this parameter is not set during the eclipse build and I get an error about the same. Did anyone encounter the same problem or is there any way-around. Any help would be greatly appreciated. Thanks, Paul
The macro name you define must appear in the command line arguments passed to the compiler. As I recall, CPPFLAGS isn't there. Try putting your -dparameter=value in CFLAGS instead of CPPFLAGS. You could also modify the command line arguments to include $(cppflags)
