I have a design with hardware writing 32-bit data in a 32-bit memory and software (written with Eclipse and running on a Nios II processor) reading it. I start reading from **_BASE address found in the “system.h” file (as an int* pointer) and then incrementing it by one for a moment. I read a simple byte that is repeating 4 times and so on… So I don’t understand the address correspondence and what I’m reading. Could someone tell me? Thanks. PS: I often have a “database error” when trying to post and then I’ve lost my message and I should type everything another time. Is it a server problem? Should this be changed?Link Copied
To be more precise:
my design is writing data(31 downto 0) but I'm reading data(7 downto 0)&data(7 downto 0)&data(7 downto 0)&data(7 downto 0). I know I'm mistaking somewhere but I don't know where. Please help me.- Mark as New
It's OK. The "byte enable" signal was not configured correctly.
Topic Options
