Hi everyone,
I have sucessfully integrated the Altera Avalon MM Read Master template. However, this only works properly up to the length of 20. (word size is 32 bit) When I define the transfer length to be 24, i.e. 6 words, then there are only 5 dataavailable assertions with 5 buffered data. What I find interesting is, that the signal early_done does get asserted, meaning the last read is actually posted, but the signal done is never asserted, so somehow the result cannot be returned. I already used a FIFO of size 64, so should be big enough I think. Is this a known issue? Or anyone an idea what the problem could be? Best regards, JimmyLink Copied
Hi, it will be faster to write Avalon MM Read Master by yourself than try debugging these templates. There are 3 parts here: send read addresses, react on waitrequest and collect incoming data on the bus.
Topic Options
