12409 Discussions
Altera Cyclone IV Programming .elf file to flash?
I am working on a DE2-115 dev board and have finished my design.
Now i need to program Flash memories so that my code will be non-viotile.
I have successfully converted the .sof file to .pof and programmed a Active Serial device EPS64.
However I cannot get the .elf file programmed in the ISSI 8MB Flash correctly. I followed the tutorial on terasic http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=49&no=656
by creating a CFI flash controller ,creating a tri-state bus and setting the reset vector to cfi_flash. I am able to program the flash and everything seems ok, but the code is not running correctly.
Any idea why this could be happening? If i run as 'Nios II hardware' in eclipse the program works great, but if i flash the .elf file and recycle power I get strange things like half of the program works. My LCD display works, but the UART doesn't.
Any ideas?
hi
You can find many topics with the same doubts here at forum
cheers
can someone at least tell me,
when i hit the 'Run as NIOS II Hardware' in the eclipse IDE, what exactly is this doing?
This can be a clue for me to fix my issue.
when you hit run the nios 2 download your software to your sopc ram............
if you want to boot your sopc from flash you need to convert your .elf file to .flash file and write to flash ........
your exception vector need to point to ram and reset vector to flash
you are use epcs and cfi flash at your design?
Yes.
I converted the .sof file to be programmed on the EPCS flash. This looks to be good.
I converted the .elf file to be programmed on CFI FLash. This also seems good, and verification comes back with a successful result.
I have pointed Reset vector to CFI flash and Exception vector to op-chip memory.
I am thinking the problem may have something to do with the code running much quicker in RAM than it does in Flash? I thought I read that the boot process automatically takes the Code from Flash and puts it into RAM before its starts to execute the program? Is this true, Do i need to do anything to make this happen?
I am using NIOS Economy
ok
why you dont use only the epcs flash........... you put the .sof and .elf in epcs
put .sof and .elf at same directory .....at command shell enter in this directory
convert the .sof
sof2flash --input=(your.sof) --output=(yoursof.flash) --epcs --verbose --offset=0x0
write the yoursof.flash
nios2-flash-programmer --epcs --debug --base=(yourepcsaddress) yoursof.flash
yourepcsaddess = epcs base address + pipeline bridge(if you use) + clock crossing bridge (if you use)
to convert .elf type
elf2flash --after=(yoursof.flash) --input=(your.elf) --output=yourelf.flash --epcs --boot=/home/altera/11/ip/altera/nios2_ip/altera_nios2/boot_loader_epcs.srec
write the yourelf.flash
nios2-flash-programmer --epcs --debug --base=(yourepcsaddress) yourelf.flash
reboot your system (reset vector =>epcs_controller exception vector => ram)
