12604 Discussions
Altera Monitor Program vs Quartus II web v15?
Hi all,
I bought a BeMicro MAX10 board and I'm reading the tutorial on Qsys. This is an example to create a Nios II project. It says that that it will use the Altera Monitor Program to download the design to the FPGA. I'm familiar (and d/l) the Quartus II web v15 software but I've never heard of the monitor program. The description for the monitor program says:
The Altera Monitor Program allows students to easily compile and debug both assembly language and C programs. It supports both the ARM® Cortex®-A9 and Nios® II processors.
Do I really need it or Quartus II web v15 is enough?
You can use Quartus and/or Altera Monitor Program.
UniversityProgram has also interesting IP to play with.
