The issue is when I manually measure it comes to 0.95V. But when we read the values it comes around as below. channel2 = 2d, Vcc = 0.879V Kindly Suggest how to get the readings as we measure practically. What may be the issue? Regards, Bhavishya AJLink Copied
What is the resolution or accuracy of your measuring instrument? The difference in measurement can be error/offset of instrument which is added in your measurement, Because of accuracy which also based on range selected on instrument. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
