Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Arria 10 with separate hardened DDR controller for PL and HPS
I have come up with a set of requirements for the memory and I realized my PL memory needs are critical.
I understand there is a x72 DDR4 hardened PHY+Controller+MPFE in the Arria10 and I'd like to reserve it for the PL.
We will also need external memory access for the Linux O/S running on the HPS.
Is there a second DDR hardened PHY+Controller+MPFE that I could use for the HPS?
Eric
Highlighted
Yes, you can have external memory on both HPS and FPGA, as shown in the attached picture.
I encourage you to read the following doc to know more about the I/O bank assignments for the HPS:
https://www.altera.com/en_us/pdfs/literature/an/an-a10-soc-device-design-guidelines.pdf
Is there linux support to access FPGA DDR?
Highlighted
--- Quote Start ---
--- Quote End ---
Are you saying you would like to use HPS to access the FPGA DDR memory over the H2F bridge? Right now I don't think the HPS can support 2 memory controller instances (one in its own HPS DDR and the other FPGA memory) - besides, it would be quite inefficient to do it over the H2F bridge. I believe letting the FPGA access the HPS DDR over the F2S bridge is a better alternative.
