12437 Discussions
Avalon-MM-Slave address alignment
Hi All
I have aquestion regarding the address alignment of a an-MM slave.
My MM-Save has an avs_readdata and avs_writedata port each 512 bit wide.
Now I'm trying to write the custom pripheral driver for the NIOSII.
There I have to asign the correct address for read and write data but which comes first?
IOWR(base,0,data) IORD(base,513)
or vice versa?
Thank you for your answer!
Ben
Since the Nios can only do 32bit Avalon master cycles, you really don't want a 512bit wide slave.
You'll only get a bus width adapter that will assert the revelant byte enables for the address.
It is probably much better to write a 32bit slave.
I'm not sure what your problem with IORD() and IOWR() is - they are just wrappers that generate ldio and stio instructions.
As such their definitions aren't entirely useful.
Most device driver writers use C structures to map device registers, it is much less error prone than using integer offsets.
Hi dsl
You're right, I now changed my Avalon MM slave Custom peripheral to us it with burst transfer.
However, I don't know how the _regs.h file needs to look.
For example, how to I write my 32bit width data over the IOWR() makro on the right position of my 512bit wide slave avr_writedata?
Do I need to set the bytenable or address bits? But how?
Thank you for your help
IIRC the Nios won't generate burst transfers either (except maybe for cache line transfers).
So qsys will probably have added a burst adapter!
Personally I'd just define the correct values and ignore the Altera definitions - they just confuse things.
qsys will show a base address for your slave of (say) 0x123000, fix this rather than letting qsys assign the addresses.
In your header file:
#define MY_SLAVE_BASE 0x123000 struct { volatile unsigned int reg_0; .... } my_device registers; extern struct my_device *my_device;
In your source, and assuming you aren't using the MMU:
struct my_device *my_device = (void *)(0x80000000 | MY_SLAVE_BASE);
Then you can access my_device->reg_0 the same as any other variable.
The fabric will convert the low address bits into byte enables for you.
But note that the nios always does 32bit reads, char/short writes will assert the expected byte enables.
If I declare my struct like you stated above and I try to write to reg_0 with
<CODE> my_device->reg_0 = 1;<\CODE>
my NIOS stops working.
However, if I check the address in debug mode of my_device it's the right one.
Hi dsl
I was following the thread with great interest since I'm struggeling with something very similar. Thanks for the enlightenment!
--- Quote Start ---
--- Quote End ---
If this is the case, how can I force it to make the burstcount as big as the number of symbols to be read, in order to
prevent having the burst divided into a bunch of smaller ones?
I'm trying to transfer a 512 Bit package using your mentioned cache-method.
Thanks, Markus.
It is a long time since I've looked at the options.
ISTR there being one to request the cache do bursts.
But it won't generate bursts longer than a cache line.
An alternate approach is to dual port an M9K block as tightly coupled data memory.
That will give the nios the same access times as a data cache hit.
You need to make sure the m9K block is set for OLD_DATA (which implies single clock mode).
thanks for your answer!
--- Quote Start ---
--- Quote End ---
The cache line is defined as 32, but the Nios refuses to make bursts longer than 8. I'd be perfectly fine with a 32-wide burst. This applies to both read and write bursts. :(
Isn't a burst of 8 transfering 32 bytes?
Both avs_readdata and avs_writedata are 32 Bit wide, so in order to have my 512 Bit package delivered, a burst of 16 is needed (whereas a burst of 8 is only half the rent). Please correct me if I'm wrong..
--- Quote Start ---
--- Quote End ---
now I see your point, sorry! Your're right of course. But I need to transfer 64Byte.
