Avalon and 8-bit CFI
Hi Al,
I know I discussed this once before with wentao ... but I'd like to confirm ... since I seem to be
having one of those "senior moments" ;-):
http://forum.niosforum.com/forum/index.php...t=1130&hl=jffs2 (http://forum.niosforum.com/forum/index.php?act=st&f=18&t=1130&hl=jffs2
Using the toggle bit (DQ6) to test for flash erase/write operation in progress won't work with the avalon
bus because the avalon bus performs 4 consecutive reads of an 8-bit device, correct?
i.e. -- for a single 8-bit CPU read, the avalon bus does 4 external bus cycles, and DQ6 does the
following: 1 -> 0 -> 1 -> 0 ... and the subsequent CPU read will never see DQ6 change state.
So, data polling via DQ7 is the way to go ... do I have this right?
--Scott
