12603 Discussions
Avalon mm mapped slave, issue with read
MBena2
Hi there, I am using the DE0 Nano Soc (cyclone V), I am abble to write data from HPS to FPGA using the avalon mm slave, but when I want to write from the fpga to HPS using the avalon mm slave, the HPS crash, indeed the linux terminal is blocked, I can write anithing on it.
I am using this simple code for the moment.
process(clock)
begin
if rising_edge(clock) then
if read = '1' then
readdata <= "10111010001100110011001100110000";
end if;
end if;
end process;
the same code but with a write condition works well.
Fawaz_Al-Jubori
May I know what address are you trying to read/write? is it memory? or peripheral?
