I am using the AvalonMM Pipeline Bridge to connect different custom blocks.
I do not see the Avalon MM Pipeline Bridge Driver in Eclipse after the Quartus compilation and after I regenerate the bsp.
Moreover the system.h does not include base address for the AvalonMM Pipeline Bridge.
Quartus 17.1Pro device Arria10
Do you have any explanation?
Paolo.
No, we don't need any API to operate or control that bridge. It just helps to transfer from master to slave module seamlessly. You can refer to Qsys system .qsys or <qsys system name>.html to find out the bridge base address.
Thank you for the explanation.
Paolo.
