I am trying to build a project in NIOS but it is giving "undefined reference to `tse_mac_device' " error. I am using NIOS II-Eclipse, Quartus 15.1 and Altera's DE2-115 board.
The error occurred in two files generated by Eclipse: error in 'altera_avalon_tse' line 119 tse_mac_device[tse_system_count].tse_mac_base = pmac->tse_mac_base + (i * 0x400); error in 'ins_tse_mac file' line 342 if(tse_mac_device.tse_mac_base == p_driver_data->hw_mac_base_addr){
psys_info = &tse_mac_device; } Here is the error report from NIOS when I tried to build the project: 20:02:08 **** Incremental Build of configuration Nios II for project OpenTOF **** make all Info: Building ../OpenTOF_bsp/ C:/altera_lite/15.1/nios2eds/bin/gnu/H-x86_64-mingw32/bin/make --no-print-directory -C ../OpenTOF_bsp/ [BSP build complete] Info: Linking OpenTOF.elf nios2-elf-g++ -T'../OpenTOF_bsp//linker.x' -msys-crt0='../OpenTOF_bsp//obj/HAL/src/crt0.o' -msys-lib=ucosii_bsp -L../OpenTOF_bsp/ -Wl,-Map=OpenTOF.map -O0 -g -Wall -mno-hw-div -mhw-mul -mno-hw-mulx -o OpenTOF.elf obj/default/OpenTOF_lib.o obj/default/main.o obj/default/network.o -lm -msys-lib=m ../OpenTOF_bsp/\libucosii_bsp.a(ins_tse_mac.o): In function `altera_eth_tse_init': C:\Users\achoo\Desktop\OpenTOFv2.2\OpenTOFv2.2\Firmware\OpenTOF_bsp/drivers/src/iniche/ins_tse_mac.c:119: undefined reference to `tse_mac_device' C:\Users\achoo\Desktop\OpenTOFv2.2\OpenTOFv2.2\Firmware\OpenTOF_bsp/drivers/src/iniche/ins_tse_mac.c:119: undefined reference to `tse_mac_device' C:\Users\achoo\Desktop\OpenTOFv2.2\OpenTOFv2.2\Firmware\OpenTOF_bsp/drivers/src/iniche/ins_tse_mac.c:120: undefined reference to `tse_mac_device' C:\Users\achoo\Desktop\OpenTOFv2.2\OpenTOFv2.2\Firmware\OpenTOF_bsp/drivers/src/iniche/ins_tse_mac.c:120: undefined reference to `tse_mac_device' ../OpenTOF_bsp/\libucosii_bsp.a(altera_avalon_tse.o): In function `alt_tse_system_add_sys': C:\Users\achoo\Desktop\OpenTOFv2.2\OpenTOFv2.2\Firmware\OpenTOF_bsp/drivers/src/altera_avalon_tse.c:342: undefined reference to `tse_mac_device' ../OpenTOF_bsp/\libucosii_bsp.a(altera_avalon_tse.o):C:\Users\achoo\Desktop\OpenTOFv2.2\OpenTOFv2.2\Firmware\OpenTOF_bsp/drivers/src/altera_avalon_tse.c:342: more undefined references to `tse_mac_device' follow collect2.exe: error: ld returned 1 exit status make: *** [OpenTOF.elf] Error 1 20:02:09 Build Finished (took 1s.425ms)
Review the Simple Socket Server example. tse_mac_device is a structure you define in your application project files.
Have you searched for all Build.err and Build.log files under the
PLATFORM directory and compared the contents of files of the same directories for (a) build from the original BSP versus (b) build from the cloned, failing BSP? Very often one of these log files will provide you with the clue that you need.
