Basic NIOS II interrupt.
I am getting the warning.
--- Quote Start ---
warning: implicit declaration of function 'alt_irq_register'
--- Quote End ---
Call in code is
alt_irq_register(CODEC_SIMPLE_MASTER_2_0_IRQ_INTERRUPT_CONTROLLER_ID, (void *) NULL, codec_isr);
I have also included <alt_irq.h>
Can I ignore this warning?
Have you implemented the internal irq controller or the VIC?
If the latter, you must use the enhanced interrupt APIs: alt_ic_isr_register
--- Quote Start ---
--- Quote End ---
The internal interrupt controller.
Try # include "alt_legacy_irq.h"
although this should be automatically included by alt_irq.h whenever the enhanced irq APIs are not enabled, namely if you don't use the external irq controller.
I am now getting
warning: alt_legacy_irq.h: No such file or directory
--- Quote Start ---
I am now getting
--- Quote End ---
Ok....
I included
# include "priv/alt_legacy_irq.h"
Now I get warning.....
"passing argument 3 of 'alt_irq_register' from incompatible pointer type"
Prototype for alt_irq_resgister in priv/alt_legacy_irq.h is
extern int alt_irq_register (alt_u32 id,
void* context,
alt_isr_func handler);
As I said my file calls
alt_irq_register(CODEC_SIMPLE_MASTER_2_0_IRQ_INTERRUPT_CONTROLLER_ID, NULL, codec_isr);
codec_isr is handler and is defined as
static void codec_isr(void * context, alt_u32 id)
Search the headers for the definition of alt_isr_func, probably doesn't quite match the function you supplied.
Or my 'trick', add -E to the gcc command file and then open the .o file in a text editor and search through the pre-processed output.
(Might be difficult from the IDE)
--- Quote Start ---
--- Quote End ---
From alt_irq.h all I can see is this.
# ifdef ALT_ENHANCED_INTERRUPT_API_PRESENT
typedef void (*alt_isr_func)(void* isr_context);
# else
typedef void (*alt_isr_func)(void* isr_context, alt_u32 id);
# endif
Hmmm...
I'd try removing the u32 parameter and see if the warning goes away.
If that is what the compiler is complaining about you need to sort out whether you should be using the enhanced interrupt api or not.
Eveything will need to be consistent.
I included the line
# undef ALT_ENHANCED_INTERRUPT_API_PRESENT
In my main c file.
The warning went away.
I am rusty on this. Probably a better way of doing this.
The warning might have gone away, but that doesn't mean the actual call (to your ISR) will provide the extra parameter.
I'd guess there is some BSP config option that sets it.
I can't see any BSP config however this is where I am at.
I got the thing to build again using
And using Enhanced Interrupts.
I set up the interrupt in code by calling
alt_ic_isr_register (CODEC_SIMPLE_MASTER_2_0_IRQ_INTERRUPT_CONTROLLER_ID, CODEC_SIMPLE_MASTER_2_0_IRQ, codec_isr, NULL, 0x0);
My interrupt service routine is.
static void codec_isr (void *context)
This builds fine however the processor seems to hang when the interrupt is asserted.
I did an enhanced interrupt based PIO based project and I can get into the interrupt here (to check if my setup was correct).
So my custom peripheral's interrupt seems to hang the NIOS II processor. (The main loop is no longer running).
Weird.
Any ideas?
Found the problem.
Me and my software bugs.
I was setting up the DMA with a wrong address and probably overwriting a critical area of memory.
Ooops.... :oops:
only you include# undef ALT_ENHANCED_INTERRUPT_API_PRESENT and dissapear the warning???
I've incluided this line, but the warning continues, and the interrupt doens't work
Help me in this problem
By default ALT_ENHANCED_INTERRUPT_API_PRESENT is defined. Therefore you need to set up with the interrupt prototypes for these given in the appropriate header file.
