I'm using the Arrow BeMicro SDK and we develop our application based on the Simple Socket Server example. We now need to port our application from SUPERLOOP to MicroC/OS-II version. While in DEBUG mode I have isolate that the program fail to create the 20th semaphore in targnios.c. (when I==19 in code below: for (i = 0; i < GLOBWAKE_SZ; i++) { global_TCPwakeup_set.ctick = 0;global_tcpwakeup_set.soc_event = NULL; global_TCPwakeup_set.semaphore = ossemcreate(0);
if (!global_tcpwakeup_set.semaphore) panic("globwake_semaphore create err"); } ERROR MESSAGE ON JTAG UART: panic: globwake_semaphore create err dtrap - needs breakpoint thanks for your help
found how to go further (Qsys related). Now I'm at that point :
InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 Your Ethernet MAC address is 00:07:ed:01:23:45 Static IP Address is 192.168.1.2 prepped 1 interface, initializing... [tse_mac_init] INFO : TSE MAC 0 found at address 0x05000800 INFO : PHY National DP83848C found at PHY address 0x01 of MAC Group[0] INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED MARVELL : Mode changed to RGMII/Modified MII to Copper mode MARVELL : Enable RGMII Timing Control MARVELL : PHY reset INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link not yet established, restart auto-negotiation... INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : PHY[0.0] - Link established INFO : PHY[0.0] - Speed = 10, Duplex = Full OK, x=12, CMD_CONFIG=0x00000000 MAC post-initialization: CMD_CONFIG=0x06000203 [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created mctest init called IP address of et1 : 192.168.1.2 Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) Simple Socket Server starting up [sss_handle_receive] reset connection [sss_task] Simple Socket Server listening on port 3000 Created "simple socket server" task (Prio: 4) [MicroC/OS-II]: See STDERR for expanded diagnosis translation. [MicroC/OS-II]: Expanded Diagnosis: Failed to create SSSLEDLightshowSem. . [MicroC/OS-II]: See STDERR (FAULT_LEVEL is SYSTEM). [MicroC/OS-II]: FAULT_LEVEL is SYSTEM [MicroC/OS-II]: FATAL Error, Restart required. [MicroC/OS-II]: Locking scheduler - endless loop.
