12599 Discussions
Bidir Reset pin HPS nRST on 5CSEMA6F31I7N doen´t go low while POR
On our board with Cyclone V SoC 5CSEMA6F31I7N the bidirectional reset pin HPS nRST (C27) doen´t goes low while POR. We also see, when voltages fall below the POR threshold it takes several microseconds until the HPS IO-Pins changes to tristate. We have two boards that we can not contact with out Lauterbach Debugger. The boards have worked, on one board we have done some resets over the POR pin and some power on cycles.
