Bitbake Output Packages
Hey!
Referring to [1], I was wondering if it is possible to run the bitbake process and only have the green field as output. I would like to have only packages as output and then, later, I would
run the process again using these packages to create an image. So, to simplify, is it possible to run bitbake and NOT create an image in the process? If so, how?
[1]: http://www.yoctoproject.org/docs/current/yocto-project-qs/figures/yocto-environment.png
Thanks in advance.
er... I think you should be following the standard procedure, you are try to tweak the process?
