When I try to search some text in the upper right textfield of my Quartus II/13.1 (on Linux Debian), a small dialog opens "Input/Output Error" on the shell the follwoing text appears. Actually Quartus is running in a VM via NAT, but a browser inside the VM works and does not need any proxy settings.
$ quartus --64bit
XPCOMGlueLoad error for file /usr/lib/xulrunner-24.0/libxul.so:
/opt/altera/13.1/quartus/linux64/libstdc++.so.6: version `GLIBCXX_3.4.15' not found (required by /usr/lib/xulrunner-24.0/libxul.so)
Couldn't load XPCOM.
Q: How to fix this?
