Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Build Target for kernel fails
I have installed quartus sp1 and nios 2 and the microtronix linux version also on winNT ENVIRONMENT.
I had previous quartus and nios versions installed in the system.
When I tried to build the kernel target it gave me the following message:
Kind Status Priority Description Resource In Folder Location
Error .config: No such file or directory[/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.4/linux-2.6.x/Makefile] kernel_1s10 line 405
In the quickstart guide you have said that during configure kernel a DOS window will appear and that it will display some messages.
I got a DOS window but it went of immediately.
Also when i went through the building uClibc when i gave the command make menuconfig it gave the message gcc not found.
Could you suggest me a solution.
Highlighted
Re: Build Target for kernel fails
Hi There,
I am in the process of setting up an NT machine to troubleshoot the problems. I had forgotten how every time you move the mouse during the install WinNT needs to restart your computer so it&#39;s taken a bit more time than expected http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
Stay tuned...
mike
(microtronix)
Highlighted
Is this resolved?
