Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Build errors in IDE since 4.2 upgrade
Folks,
Anyone upgraded to qts 4.2 yet? I just did and now I cant build. I get this strange error:
[C:/Projects/fpga/antennaHead/QuartusHead/AntennaHeadCPU_sim/dummy_file] Error 2
There is no dummy_file at that location. I tried rebuild all, regen in SOPC builder, etc. There have been no changes to the code. Any ideas?
Highlighted
Re: Build errors in IDE since 4.2 upgrade
Folks,
Update: I found this error after my project was built...
Linking RFDev.elf...
Info: (RFDev.elf) 3817 Bytes program size (code + initialized data).
Info: 256 Bytes free for stack + heap.
Creating RFDev.elf.objdump...
Creating generated_app.sh...
Post-processing to create onchip_memory_0.hex
Syntax error: "(" unexpected
make[1]: *** [C:/Projects/sriv/fpga/antennaHead/QuartusHead/AntennaHeadCPU_sim/dummy_file] Error 2
make: *** [rebuild] Error 2
Build completed
Highlighted
Are you using also using NIOS II v1.1> I thought you have to.
Highlighted
I just installed 1.0 SP1 and I get the same error.
Highlighted
We need to upgrade to v1.1.
Otherwise you should not use Quartus 4.2!
Highlighted
That's correct. This error message will occur when using Quartus II v4.2 and Nios 1.0 sp1. You can either downgrade Quartus or upgrade Nios (I highly recommend upgrading to Nios 1.1).
