12589 Discussions
Building das Uboot for Nios2 - linker not found on Linux environment
I am trying to build Uboot for Nios2. I notice Uboot has made many changes in their build configuration.
Much of the old information for Uboot/Nios2 idid not work for me after I cloned the Uboot git repo. For example,
'boards.cfg' is no longer supported. Uboot is migrating to Kconfig for build management and there are both
Kconfig files and Make files -complicating debug.
I do the following on Linux bash.
> git clone git://git.denx.de/u-boot-nios.git
> cd u-boot-nios/
> make menuconfig
These proceeding steps complete with no visible errors or warnings.
After git clone - I can browse the Uboot source tree.
I create a minimal '.config' file.
> make all
This step fails with the following error
LD arch/nios2/cpu/built-in.o
/bin/sh: nios2-elf-ld.bfd: command not found
scripts/Makefile.build:354: recipe for target 'arch/nios2/cpu/built-in.o' failed
make[1]: *** [arch/nios2/cpu/built-in.o] Error 127
Makefile:1037: recipe for target 'arch/nios2/cpu' failed
make: *** [arch/nios2/cpu] Error 2
I tested to confirm that both 'nios2-elf-gcc' and 'nios2-elf-ld' are in the path and are executable.
It appears the compile completed (based on the message output), but the nios2 linker ('nios2-elf-ld') is not found.
I have been running Nios2 successfully on Linux.
Anyone else seen this error or found a workaround?
Dave
so you never got this success in the past? just to confirm your setup environment
I have not run Uboot on nios2. The build failed - no linker.
I have been running nios2 on the same hardware with the
same sopc file. And I have not previously built Uboot for this system.
To solve the problem of not finding the linker - I needed to set the CROSS_COMPILE environment variable
using these bash commands.
> CROSS_COMPILE=nios2-elf-
> export CROSS_COMPILE
Then run make and the build completed with no errors.
Now, I need to try to load and test on my nios2 hardware.
THIS WAS documented in the README file starting at line 4929. So I deserve a
"RTFM idiot". BTW, the README file has 6515 lines.
Dave
