I am trying to build Uboot for Nios2. I notice Uboot has made many changes in their build configuration.
Much of the old information for Uboot/Nios2 idid not work for me after I cloned the Uboot git repo. For example, 'boards.cfg' is no longer supported. Uboot is migrating to Kconfig for build management and there are both Kconfig files and Make files -complicating debug. I do the following on Linux bash. > git clone git://git.denx.de/u-boot-nios.git > cd u-boot-nios/ > make menuconfig These proceeding steps complete with no visible errors or warnings. After git clone - I can browse the Uboot source tree. I create a minimal '.config' file. > make all This step fails with the following error LD arch/nios2/cpu/built-in.o /bin/sh: nios2-elf-ld.bfd: command not found scripts/Makefile.build:354: recipe for target 'arch/nios2/cpu/built-in.o' failed make[1]: *** [arch/nios2/cpu/built-in.o] Error 127 Makefile:1037: recipe for target 'arch/nios2/cpu' failed make: *** [arch/nios2/cpu] Error 2 I tested to confirm that both 'nios2-elf-gcc' and 'nios2-elf-ld' are in the path and are executable. It appears the compile completed (based on the message output), but the nios2 linker ('nios2-elf-ld') is not found. I have been running Nios2 successfully on Linux. Anyone else seen this error or found a workaround? DaveLink Copied
so you never got this success in the past? just to confirm your setup environment
I have not run Uboot on nios2. The build failed - no linker.
I have been running nios2 on the same hardware with the same sopc file. And I have not previously built Uboot for this system.- Mark as New
To solve the problem of not finding the linker - I needed to set the CROSS_COMPILE environment variable
using these bash commands. > CROSS_COMPILE=nios2-elf- > export CROSS_COMPILE Then run make and the build completed with no errors. Now, I need to try to load and test on my nios2 hardware. THIS WAS documented in the README file starting at line 4929. So I deserve a "RTFM idiot". BTW, the README file has 6515 lines. Dave
