BusyBox use
I tried to use BusyBox package but I got the following ouput
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
On node 0 totalpages: 4096
DMA zone: 0 pages, LIFO batch:1
Normal zone: 4096 pages, LIFO batch:1
HighMem zone: 0 pages, LIFO batch:1
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 16 (order 4: 128 bytes)
Memory available: 14512k/4096k RAM, 0k/0k ROM (1365k kernel code, 303k data)
Calibrating delay loop... 39.83 BogoMIPS
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
POSIX conformance testing by UNIFIX
NET: Registered protocol family 16
Serial: JTAG UART driver : 1.3 $
ttyJ0 at MMIO 0x80920820 (irq = 1) is a jtag_uart
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
smc_probe: 80000 Khz Nios
SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6)
eth0: SMC91C11xFD(rev:1) at 0x80910300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07:ed:0c:02:16
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
CF: ctl=2
Using anticipatory io scheduler
microtronix[mtd]: RAM probe address=0x200000 size=0x1bc000
Creating 1 MTD partitions on "RAM":
0x00000000-0x001bc000 : "ROMfs"
microtronix[mtd]: set ROMfs to be root filesystem
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 1024 bind 2048)
NET: Registered protocol family 17
VFS: Mounted root (romfs filesystem) readonly.
Freeing unused kernel memory: 48k freed (0x1186000 - 0x1191000)
expand: from=/ramfs.img to=/dev/ram0
expand: from=/ramfs.img to=/dev/ram1
init: exec failed
init: exec failed
Is there any recommandation to implement it ? I am using the 1S40 Linux reference design.
