C++ Templates
Hello experts
BUG in NIOS2 C++ compiler
Declaration below, is template Class which valid (we where check it at other compilers )
///////// IT IS VALID CODE BUT COMPILER TROW ERROR!!!!
//////// look to the end of string which begin with FlatScreen ....
template <class T> class FlatScreen:public Screen
protected:
int32 line_width;
T* mData;
virtual void close(void);
//---------------------------------------------------------------------------------------------LOOK HERE
FlatScreen(int w,int h,int bpp,size_t lw,T* ptr):Screen(w,h,bpp),mData(ptr),line_width(lw?lw:w*sizeof(T)) //line_width(lw?lw:w*sizeof(T) - MUST BE ASSIGNED
assert(mData);
public:
T* GetPtr(void) { return mData; }
virtual ~FlatScreen(void);
virtual void _PutPixel(int x,int y,uint32 color);
virtual uint32 _GetPixel(int x,int y);
virtual void _vline(int x,int y,int h,uint32 color);
virtual void _line(int x0,int y0,int x1,int y1,uint32 color);
virtual void _outchar(int x,int y,uint ch,uint32 color,const cRect* rect);
virtual void _PutImage(int x,int y,const tPicture* image,const cRect* rect);
virtual void _GetImage(int x,int y,int w,int h,tPicture* image,const cRect* rect);
virtual void _BitBlt(int x,int y,int w,int h,const void* image,const cRect* rect);
To solve that problem we replace assigning of values to constuctor body
like shown below :
protected:
int32 line_width;
T* mData;
assert(mData);
line_width=lw?lw:w*sizeof(T); // Replased from constructor because nios2-elf-gcc compiler have a BUG!!!
public:
I&#39;ts fundamental BUG - and i guess it not last bug of C++ compiler .... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
So is it possible to fix BUG&#39;s of that type in NEXT release ?
Can you please post both the error message you are getting from the compiler, and if possible a reduced test case?
I guess the reason you want the initializer version of your code to work is so you can declare line_width as const int32 instead of just int32.
Do either of the following work?
FlatScreen(int w,int h,int bpp,size_t lw,T* ptr):Screen(w,h,bpp),mData(ptr),line_width(lw?lw:size_t(w)*sizeof(T))
FlatScreen(int w,int h,int bpp,size_t lw,T* ptr):Screen(w,h,bpp),mData(ptr),line_width(size_t(lw?lw:w*sizeof(T)))
And yes, please show us the actual error message.
