#include <iostream># include <stdio.h># include <stdlib.h># include "HLS/hls.h"
using namespace std; using namespace ihc; typedef mm_master<unsigned int, dwidth<32>, awidth<64>, aspace<1>, latency<0>, maxburst<1> > mm_src_t; typedef mm_master<unsigned int, dwidth<32>, awidth<64>, aspace<3>, latency<0>, maxburst<1> > mm_dst_t; # define SEED 3# define NUM_SAMPLES 8 //#define DUMP_BUFFERS int verify_data(int *src, int *dst, int count, unsigned int x=0) { int errors = 0; for(int i = 0; i < count; i++) { if(dst != (src + x)) { errors++; printf("mismatch at index %d: 0x%llx != 0x%llx\n", i, (unsigned long long)dst, (unsigned long long)src + x); } } return errors; } template<typename T> void dump_buffers(const char* title, T *ref, T *dst, unsigned size) {# ifdef DUMP_BUFFERS // Title printf("%s:\n", title); if(size == 0) return; // Reference printf(" REF:"); for(unsigned i=0; i<size-1; ++i) { printf(" 0x%04x,", ref);if(i % 8 == 7) printf("\n ");
printf(" 0x%04x\n", ref);
// destination
printf(" dst:");
printf(" 0x%04x,", dst); if(i % 8 == 7) printf("\n "); } printf(" 0x%04x\n", dst);# endif } component void add_x(mm_src_t &src, mm_dst_t &dst, unsigned int x) { *dst = *src + x; } int main () { int x = 0; int errors = 0; int src_mem[NUM_SAMPLES]; int dst_mem[NUM_SAMPLES]; // initialize data srand(SEED); for (int i=0; i<NUM_SAMPLES; ++i) { src_mem = rand() % 2048;
dst_mem = -1; } dump_buffers("Initial", src_mem, dst_mem, NUM_SAMPLES); /* 1) This code creates a new mm_master interface for each iteration of the loop. */ x = 0x10; for (int i=0; i<NUM_SAMPLES; ++i) { mm_src_t src_mm_i(&src_mem, 1*sizeof(int));
mm_dst_t dst_mm_i(&dst_mem, 1*sizeof(int)); ihc_hls_enqueue_noret(&add_x, src_mm_i, dst_mm_i, x); } ihc_hls_component_run_all(add_x); dump_buffers("New mm_master for each index", src_mem, dst_mem, NUM_SAMPLES); errors += verify_data(src_mem, dst_mem, NUM_SAMPLES, x); /* 2) This code demonstartes use of the getInterfaceAtIndex() function which can be used to index into a mm_master object. This can be useful when iterating over an array and invoking a component on different indices of the array. */ x = 0x20; mm_src_t src_mm(src_mem, NUM_SAMPLES*sizeof(int)); mm_dst_t dst_mm(dst_mem, NUM_SAMPLES*sizeof(int)); for (int i=0; i<NUM_SAMPLES; ++i) { ihc_hls_enqueue_noret(&add_x, src_mm.getInterfaceAtIndex(i), dst_mm.getInterfaceAtIndex(i), x); } ihc_hls_component_run_all(add_x); dump_buffers("Use getInterfaceAtIndex()", src_mem, dst_mem, NUM_SAMPLES); errors += verify_data(src_mem, dst_mem, NUM_SAMPLES, x); if (errors) { printf("FAILED with %d errors\n", errors); } else { printf("PASSED\n"); } }
If you want to understand what the general objective of templates use is. https://www.tutorialspoint.com/cplusplus/cpp_templates.htm Best Regards, Johi.- Mark as New
--- Quote Start --- Hello, If you want to understand what the general objective of templates use is. https://www.tutorialspoint.com/cplusplus/cpp_templates.htm Best Regards, Johi. --- Quote End --- Thanks Johi for the reply...Actually my question is only regarding to the usage of of C++ template specific to this code. I am aware of C++ template concept but somehow struggling to understand the reason of C++ template usage in this code..... :)
Topic Options
