I would like to know what is the maximum speed transfert that I can obtain on the CF card with the altcf ip of ALTERA. Does anybody know if it's possible to change PIO mode ? Thank you in advance.Link Copied
I manage to obtain ~2.5MB/s. However is it possible to obtain a better data rate ?
Bye- Mark as New
Doing an appropriate DMA interface in "hardware" might help.
-Michael- Mark as New
How can you have DMA on altcf : there's two MM Slave : ctl and ide ?
I know that's possible to make a DMA request from SRAM two DDR but how can you do that from DDR to altcf ? Regards,- Mark as New
I meant: new "hardware" instead of altcf.
Building a new CF-port hardware processor that includes a state machine and some counters. Maybe using the DMA hardware blocks provided by Altera might be possible instead, but I have no knowledge on that. Of course a completely new Linux device driver for that DMA-CF-port is necessary as a consequence with either way. -Michael- Mark as New
Does anybody know how to implement the OCIDEC core on Avalon BUS?
This IP support the DMA process over IDE . Thank you Michael- Mark as New
AFAIK, there is an Avalon/Wishbone adapter somewhere...
Avalon/Wishbone adapter ?
That is very interresting. However I have look on google and I didn't found anything. Could you tell me where?- Mark as New
See
http://www.alterauserforums.org/forum/showthread.php?t=5500 and last mail in this thread: http://www.alteraforum.com/forum/showthread.php?t=2238- Mark as New
Ok thank you...
So I have to translate the OCIDEC core from Wishbone to Avalon. However, do you thank that I will found driver for uClinux to drive my interface ?- Mark as New
I suppose there is no Linux-NIOS driver for DMA enabled CF. So you will need to create it.
Ok I have begin the translation of OCIDEC. : http://www.nioswiki.com/operatingsystems/uclinux/ocidec_on_nios2
Could you help me for the driver ?- Mark as New
I have no idea how to create a block device driver. I suppose you should try to find an example for a DMA block device driver (e.g. the IDE driver for PC architecture). (But I do know that the IDE PC driver has a long history of bugs and redesigns, so it does not seem to be exactly simple.)
-Michael- Subscribe to RSS Feed
