12603 Discussions
CPU1: failed to come online
I'm faced with Soc bootloading issue when generating the preloader:
Context:
- Tools: QUARTUS_VERSION 15.0.0
- HW: Cyclone V - 5CSXFC6D6F31C6
- SW: boot from MMC
Before:
- A design works fine with two cores activated.
Action:
- From the working design, Preloader is been re-generated using bsp-editor.
Now:
- cpu0 activated, cpu1 failed to come online.
Question: how to activate cpu1 ?
Hi, did you added in the cpu start address from the DTS generation?
--- Quote Start ---
--- Quote End ---
in "soc_system.dts" file:
hps_sysmgr: sysmgr@0xffd08000 {
compatible = "altr,sys-mgr-14.0", "altr,sys-mgr", "syscon";
reg = < 0xFFD08000 0x00004000 >;
cpu1-start-addr = < 4291854532 >; /* embeddedsw.dts.params.cpu1-start-addr type NUMBER */
}; //end sysmgr@0xffd08000 (hps_sysmgr)
dtc file has not replaced into mmc: it is the same before and after preloader re-generation.
check out for the key word "cpu1", be sure not to change the kernel version(in case if you rebuild your self).
http://rocketboards.org/foswiki/view/documentation/gsrdv151devicetreegenerator
DeviceTree file (dtc) and kernel image (zImage) have not been changed. The only change made on the SD card is preloader.
Preloader will leave cpu1 in default state / power on state which is in reset.
cpu1 will be brought out by Linux from Linux.
That's probably right. But I don't manage to understand why regenerating preloader prevents linux to brought out cpu1.
--- Quote Start ---
--- Quote End ---
hi, to enable the cpu1, you maybe need to enable this in device tree, and not the preloader. Maybe you can explain alittle more what are your ACTIONS did..
