I used EPCQ16ASI8N to replace EPCS16SI8N, but I found out that I can't burn the program.I found in the datasheet that the structure of EPCS16SI8N is AS × 1, EPCQ16ASI8N has AS × 1 and AS × 4.The ordering code of EPCQ16 is only EPCQ16ASI8N. How do I judge the structure I bought?
The EPCQ16 supports all the operations that the EPCS16 does. It will also work quite happily in x1 mode. So, yes - you should be able to use the EPCQ16 in place of your old EPCS16.
You don't say what tools/software you're using to program the device. The EPCQ and EPCS devices will have different identifiers. Some programmers - e.g. the nios-flash-programmer software - simply refuse to program a device whose identifier it doesn't recognise.
Cheers,
Alex
I use Quartus II to program the device. I see that there is a way to enable the Disable EPCS/EPCQ ID check option in guidance, but the software used is Quartus Prime. How do I use Quartus II to block ID checks?
Thank you for your help.
Tom
You have to disable the check via the 'Convert Programming Files...' window. Click on the 'Advanced' button.
Cheers,
Alex
I have been able to burn normally.
Thank you for your hrlp.
Tom
