12600 Discussions
Can Qsys implement two processor with sharing 2 ddr2 sdram?
the scheme is : on Stratix IV EP4SGX230
{Processor1 Processor 2}
|/ _________ \|
{ddr2SDRAM1 ddr2SDRAM2 }
operations:
1,time1 ,Processor 1 ACESS SDRAM1,Processor 2 ACESS ddr2SDRAM2
2,time2 ,Processor 1 ACESS SDRAM2,Processor 2 ACESS ddr2SDRAM1
and so on ....
can this be implemented? and how ? is there any docs to refer?
thanks for your help!
The Avalon bus arbiters will allow both cpu (and any other Avalon masters) to access the memory - so there is not physical problem.
Logically you need to setup the software address maps so that the two processors aren't trying to use the same part of the memory.
