Hi All,
I am testing DMA in my project, but when compiling the c kode, i get some Errors i dont understand. error: `ALT_IRQ_NOT_CONNECTED' undeclared (first use in this function)[system_description/alt_sys_init.c] the file alt_dev.h contains a line:# define ALT_IRQ_NOT_CONNECTED (-1) Can anybody help me? my c kode is shown below: # include "ALTERA_AVALON_PIO_REGS.H"# include <stdio.h># include <stddef.h># include <stdlib.h># include "system.h"# include <alt_dev.h># include "alt_types.h"# include "sys/alt_dma.h" /* Global DMA "transaction finished" flag */ volatile int rx_done = 0; static volatile long sour[100]; volatile long *pram2= (long*)RAM2_BASE; unsigned int offset; int rc; static void dma_done (void* handle, void* data) { rx_done++; } static int MemDMATest(unsigned int memory_base, unsigned int nBytes) { alt_dma_txchan txchan; alt_dma_rxchan rxchan; /* Create the transmit channel */ if ((txchan = alt_dma_txchan_open("/dev/dma_0")) == NULL) { //printf ("Failed to open transmit channel\n"); exit (1); } /* Create the receive channel */ if ((rxchan = alt_dma_rxchan_open("/dev/dma_0")) == NULL) { //printf ("Failed to open receive channel\n"); exit (1); } //* Use DMA to transfer from write buffer to memory under test */ /* Post the transmit request */ if ((rc = alt_dma_txchan_send (txchan, (void*) sour, sizeof(sour) x sizeof(long) , NULL, NULL)) < 0) { // printf ("Failed to post transmit request, reason = %i\n", rc); exit (1); } /* Post the receive request */ if ((rc = alt_dma_rxchan_prepare (rxchan,(void*)pram2 , sizeof(sour) x sizeof(long), dma_done, NULL)) < 0) { //printf ("Failed to post read request, reason = %i\n", rc); exit (1); } /* Wait for transfer to complete */ while (!rx_done); rx_done = 0; /* Use DMA to read data back into read buffer from memory under test */ /* Post the transmit request */ if ((rc = alt_dma_txchan_send (txchan,(void*)pram2 , sizeof(sour) x sizeof(long), NULL, NULL)) < 0) { // printf ("Failed to post transmit request, reason = %i\n", rc); exit (1); } /* Post the receive request */ if ((rc = alt_dma_rxchan_prepare (rxchan, (void*) sour, sizeof(sour) x sizeof(long), dma_done, NULL)) < 0) { // printf ("Failed to post read request, reason = %i\n", rc); exit (1); } /* Wait for transfer to complete */ while (!rx_done); rx_done = 0; } int main(void) { MemDMATest(memory_base, nBytes); } return (0); } SEMIRLink Copied
This probably means that you didn't connect up the IRQ to one of your peripherals when you ran SOPC builder. Have a look in system.h to find out which one.
If this doesn't help then please post your system.h here.- Mark as New
It looks like you were close to answering your own question. The file altera_avalon_dma.h is missing the line:
# include "sys/alt_dev.h" if you add that in, the error will go away. Alternatively, you will find that this problem will also disapear if you include either a JTAG_UART or UART in your design (since these drivers will include the missing header for you).
