hello,everyone:
i used some open cores,but i am sure that the connection cable and the Power are all right ,why dose Quartus give me this message? Info: Ended Programmer operation at Wed Jun 15 09:19:43 2005 Info: Started Programmer operation at Wed Jun 15 09:20:50 2005 Info: Configuring device index 1 Info: Device 1 contains JTAG ID code 0x020930DD Info: Configuration succeeded -- 1 device(s) configured Info: Successfully performed operation(s) Info: Ended Programmer operation at Wed Jun 15 09:20:55 2005 Error: Can't communicate with device. Device will stop functioning when it reaches its non-tethered mode timeout limit. Error: Can't communicate with device. Device will stop functioning when it reaches its non-tethered mode timeout limit.Link Copied
