12600 Discussions
Can't synthesize Nios II without IP license
I'm trying to evaluate a Nios II design using Quartus II 11.1 sp1. I get the following error from Quartus:
Error (204012): Can't generate netlist output files because the file <file> is an OpenCore Plus time-limited file
The KB says to turn off IBIS file generation to fix this but it's not on.
All the documentation says that I should be able to evaluate a Nios II core without having to buy the license first.
--- Quote Start ---
--- Quote End ---
You can.
Does the overall compile give you Success?
Which file is it?
You've disabled core evaluation option. It's somewhere deep in project options...
--- Quote Start ---
You can.
Which file is it?
--- Quote End ---
No, it does not. It doesn't even try to fit the design. Just a bunch of these errors. I'm using the free web version of Quartus. Does that make a difference?
The "Disable OpenCore Plus hardware evaluation" option is set to OFF.
Nope.
I use free version too. No problems.
Are you using a non Altera IP core in your design?
Tools -> license setup and be sure to include IP core license there.
--- Quote Start ---
Nope.
--- Quote End ---
No, it's just a Nios II with RAM and DMA. No other IP.
Hmmm
Try assignments - > Settings -> EDA Tools settings.
Make sure the Tool names are set to none. I wonder if it is trying to generate a netlist for that.
i'm guessing its EDA Netlist Writer giving that error. i don't think you can generate a chip simulation netlist without a license
--- Quote Start ---
Hmmm
--- Quote End ---
Yes, that was it. I had ModelSim-Altera selected for simulation and setting it to "none" fixed the problem. Thanks to everyone for their help.
I had the same problem with my quartus II 11.1. Now I have fixed it. Thanks to rob18767
Thanks, this post helped me.
