Cgi error in boa
Hello everyone.
I've read all the topics about cgi scripts in boa.
when i try to do a simple submit button tha will call a cgi script the server "thinks"
writes: web site found, waiting for replay
and then show me an error msg...
but when i try to run the script directly from IE i see the text that it should return and it is working... (ony the scipt works)
can someone help me...?
my html file :
<form method="post" Action="http://192.168.0.20/cgi-bin/test.cgi">
<input type="submit" value="ok">
</form>
my cgi file:# include <stdio.h>
void main(void)
printf("content-type: text/html\n");
printf("\n");
printf("the cgi script is working\n);
exit(0);
my error :
the page cannot be displayed
cannot find server or dns server
tnx alot guys
Asi
Here&#39;s how I implemented your functionality...
<html> <head>    <title>CGI script test</title> </head> <body>    <form method="get" action="cgi-bin/test.cgi">    <input type="submit" value="ok"> </form>
## cgi-bin/test.cgi# # ! /bin/sh echo "Content-type: text/html\n\n" echo echo "The cgi script is working\n"
I didn&#39;t use an actual executable so my solution is definitely slower since it&#39;s done via scripting but it does work. I also used the "get" method instead of the "post" method for the form. I&#39;m not sure if the "post" method is properly implemented in boa for our distribution.
Hope this helps.
tnx Ken Wong
it really helps
