I am investigating a issue with HPS SDRAM. What i am doing here is changing some HPS SDRAM parameter in Qsys and recompile HPS.
My question is do i need to rebuild the whole FPGA to make the HPS change active? If not, then it will save us lots of time for debugging. Thank you.Link Copied
If I am not mistaken, you only need to regenerate the Qsys component --> that will regenerate the hardware-software handoff files (including the calibration needed for the HPS SDRAM). Then it is a matter of updating the preloader with the latest changes... (again, assuming you are using the bsp-editor tool to generate the preloader that calibrates the SDRAM)
Thank you, Sunshine.
That is my guess too. Yes, i am using bsp-editor to update preloader.- Mark as New
No, I tried. If I just regen the HPS in Qsys, but do not recompile the whole FPGA, it turned out the hps_isw_handoff files are not updated at all....
