Hello ,
does Anybody know how to change path to *.sopcinfo file in existing project? I am trying to change that path in NIOS II IDE 10.1. Project is based on BSP. Best regardsLink Copied
I'm actually stuck with this same problem. I'm using Nios II BSP Editor 13.1 Build 162.
You can go ahead and edit the settings.bsp file; it's just XML.
I usually edit mine to force a relative path to the .sopcinfo when an absolute path might have been placed there by the tool.
Topic Options
