Hi
I want to know how I can change the address where the program will be copied into the RAM. Right now everytime I build the app the srec2flash utility reports that the app spans from 0x1000000 to 0x1007628. How can I change this so the app is put somewhere else in the RAM??? Regards GreateWhite.DKLink Copied
There are hooks in the srec2flash utility that should allow you to do this. Here's an output that I get by running 'srec2flash' with no arguments:$ srec2flash
flash address: 0x00140000
ram address: 0x00000000
max copy size: 0x00000000
srec2flash <filename>.srec
--flash_address=x Where in flash to store the copier & program,
(defaults to 0x140000)
--ram_address=x Where in RAM to copy the program to, and execute
(defaults to 0x40000)
--copy_size=x How many bytes to copy from flash to RAM
--sdk_directory=<dir> Specify an sdk directory
"srec2flash"
The Nios development board's Germs monitor looks
for code in flash memory. The srec2flash utility
takes code targeted for program memory and
prepends a copying routine to copy itself from
flash memory to program memory. It also prepends
the necessary Germs monitor commands to write
the file into flash.
The output, <filename>.flash, can be burnt to
flash by using nios-run:
nios-run -x <filename>.flash
(Only works over serial; nios-run over jtag
does not support this feature.)
In other words, this command does return the default values, when run with no arguments, but by using the --ram-address=<your_new_location> option, you should see the behavior that you want. Hope this helps. Cheers, - Brendan
If its a simple program just use -b build option to set the base address? I use it all the time to relocate srec files:
nb -b 0x1000600 my_prog.c This gives germs that starts at 0x1000000 enough room so that I can load and reload new builds over the serial port without rebooting my board. Ken- Mark as New
Did this solve the problem?
