12589 Discussions
Changing the play back rate of a buffer in C?
Hello!
I am using an Altera DE2 FPGA board and running Quartus II, Nios II (V10.1). I loaded the Terasic V1.6 demo "DE2_SD_Card_Audio."
Currently, I can play a .wav file from the SD card to the Line Out. Ignoring all the other details, the C code (hello_led.c) from the demo that outputs to Line Out is:
UINT16 Tmp1=0;
Tmp1=(Buffer[i+1]<<8)|Buffer[i]; //loads the data from the SD card to Tmp1
//change the buffer rate?
IOWR(AUDIO_BASE, 0, Tmp1); //sends Tmp1 data to Line Out
If I were to print Tmp1, it's basically the points on a sine wave. What I want to do now is fiddle with how the sound plays by changing the play back rate (ideally I want to play the sound up or down an octave, which is just double or half the frequency). Can anyone provide some suggestions on how I can do this in the section:
Is it possible in C to write a few lines of code in that section to obtain what I'm looking for? ie. change how fast I'm reading from the Tmp1 buffer to the AUDIO_BASE.
Thanks in advance!
~Sarengo
Here are some options
-simple software delay loop
-timer interrupt with a variable interrupt frequency based upon how fast you want to set the DAC
-Software writes samples to a FIFO and statemachine, which writes data out to a DAC at a particular output rate specified by the software
http://www.dspdimension.com/admin/time-pitch-overview/
