Can it be possible to generate a Clock of 1 Mhz/ 125 Kbps from Code in eclips environment.
I have altera DE2_115 board, working on clock rate of 50Mhz regards kaushalLink Copied
Depends exactly what you want to do. I know some people have used a gpio module and generated a "clock" on it for use with an external mdio interface to a phy. They set the data bit, and tick another gpio as a clock.
