Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Comm w/ Nios II Windows XP & UART
Does anyone have any examples of comm code that can run on Nios II and a Windows XP machine? Code allows user to select file on Windows XP and load to designated memory in Nios II space.
I am trying to update some RGB images on a custom Cyclone board. I only have a UART as a comm channel.
Highlighted
Re: Comm w/ Nios II Windows XP & UART
Either of the boot monitors u-boot or redboot will do this. With u-boot you can do a 'loadb 0x100000' on the target and then do a 'send file' in hyperterm to download a binary file. Once the file is downloaded you can burn it to flash. The individual steps can be automated.
Highlighted
Thanks for your input.
I will look into u-boot.
-Ray
