12603 Discussions
Communication between SL811 and NIOS
did anybody knows what this errors means????
# usb 1-1: new low speed USB device using address 4
usb 1-1: control timeout on ep0out
usb 1-1: device not accepting address 4, error -110
usb 1-1: new low speed USB device using address 5
usb 1-1: device not accepting address 5, error -108
i'm using the sl811hs
i still can not make it comunicate well... could anybody help me...
Jimmy
u can see the error code in include/asm-generic/errno.h
then in documentation/usb/error-codes.txt to see the causation of the error. 110 means timeout.
by the way,
how many setup/wait/hold cycles while you setting the sl811 scheduling as user logic???
thanks,
well... in the setup i have 2ns,
in wait 65ns
and in hold 5ns...
based on the cypress application note about the interfacing with external processors...
how you define your avalon slave addressing... as a memory or as a register
jimmy
as register,
i use altera cyclone board,and want to add usb interface.
so it's too much problems.
can you give me your usb interface module??
gwb982@163.com
thanks!!!
