I want to try if I can use all the example programs to check if I can write/read to/from the card. I am trying to execute the program idemon.c and I don`t have any result. I have connected the RJ-45 cable, and the card just to build and run the application but I only obtain this: nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: starting in terminal mode (Control-C exits) Linux version 2.6.9-uc0 (santiago@CMC-ES2) (gcc version 3.4.1 (Al It is supposed I should obtain the list of available commands. Does anyone of you has succesfully executed this program? Thanks, Ana.Link Copied
Where did you get this idemon.c from? Also is this on a dev board or your own board?
