Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Compile Failed with recursively call by uclinux project
I got some problem of porting uclinux on de2-115 board.
Top level entity name is uclinux.v
i tried to compiling project, and have error.
here is code,
module uclinux( CLOCK_50, UART_RXD, UART_TXD, DRAM_WE_N, DRAM_RAS_N, DRAM_CS_N, DRAM_CLK, DRAM_CKE, DRAM_CAS_N, DRAM_DQM, DRAM_DQ, DRAM_BA, DRAM_ADDR ); input CLOCK_50; input UART_RXD; output UART_TXD; output DRAM_CAS_N; output DRAM_CS_N; output DRAM_CKE; output DRAM_WE_N; output DRAM_ADDR; output DRAM_RAS_N; output DRAM_DQM; output DRAM_DQ; output DRAM_BA; output DRAM_CLK; wire sys_clk; uclinux uc ( .clk_clk (sys_clk), .reset_reset_n (1), .sdram_wire_addr (DRAM_ADDR), .sdram_wire_ba (DRAM_BA), .sdram_wire_cas_n (DRAM_CAS_N), .sdram_wire_cke (DRAM_CKE), .sdram_wire_cs_n (DRAM_CS_N), .sdram_wire_dq (DRAM_DQ), .sdram_wire_dqm (DRAM_DQM), .sdram_wire_ras_n (DRAM_RAS_N), .sdram_wire_we_n (DRAM_WE_N), .uart_external_connection_rxd (UART_RXD), .uart_external_connection_txd (UART_TXD) ); pllnios n0 ( .inclk0(CLOCK_50), .c0(sys_clk), .c1(DRAM_CLK) ); endmodule
and with this error message,
Info (12127): Elaborating entity "uclinux" for the top level hierarchy Info (12128): Elaborating entity "uclinux" for hierarchy "uclinux:u0" Info (12128): Elaborating entity "uclinux" for hierarchy "uclinux:u0|uclinux:u0" Info (12128): Elaborating entity "uclinux" for hierarchy "uclinux:u0|uclinux:u0|uclinux:u0" ... Info (12128): Elaborating entity "uclinux" for hierarchy "uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0" Error (12051): Project too complex: hierarchy path is too long Error (12052): Entity "uclinux" is instantiated by entity "uclinux"
why cause recursively call to 'uclinux' module in this project?
You are recusivelly instantiating module inside a module because the top module has the same name as QSys module. I would suggest you change one of them.
Thanks to You're suggestion, But I think this problem caused by 'uclinux:u0 ' macro function.
I already tried change from 'uclinux u0' to 'uclinux uc'. And then, I got same error message again.
So, What could i do solve this problem?
If the top module is named uclinux there should be no modules named uclinux in it. I would suggest you either change qsys name or top level name.
Also, this is a Verilog question and it should be in different forum.
Oh, I'm really appriciate your help.
I changed macro name from 'uclinux' to 'niosqsys', and successfully compile it.
Thank you janco.
