Nios® II Embedded Design Suite (EDS)
Support for Embedded Development Tools, Processors (SoCs and Nios® II processor), Embedded Development Suites (EDSs), Boot and Configuration, Operating Systems, C and C++
Intel Support hours are Monday-Fridays, 8am-5pm PST, except Holidays. Thanks to our community members who provide support during our down time or before we get to your questions. We appreciate you!
Need Forum Guidance? Click here
Search our FPGA Knowledge Articles here.
12453 Discussions
Compiler not detecting unused functions
I recently inherited a project and I am trying to clean it up. I have the following warnings enabled but I don't think the unused functions are being detected or at least reported by the compiler.
-Wall -Wunused -Wunused-function -Wextra
Here's a the build command for one of the source files
nios2-elf-gcc -xc -MP -MMD -c -I../gsi_proc_bsp//HAL/inc -I../gsi_proc_bsp/ -I../gsi_proc_bsp//drivers/inc -DSYSTEM_BUS_WIDTH=32 -pipe -D__hal__ -DALT_NO_C_PLUS_PLUS -DALT_NO_CLEAN_EXIT -D'exit(a)=_exit(a)' -DALT_NO_EXIT -DALT_NO_INSTRUCTION_EMULATION -DALT_STACK_CHECK -fstack-check -DALT_SINGLE_THREADED -DALTERA_AVALON_UART_USE_IOCTL -O1 -g -Wall -Wunused -Wunused-function -Wextra -mhw-div -mcustom-fpu-cfg=60-1 -mhw-mul -mno-hw-mulx -o obj/default/.metadata/.plugins/org.eclipse.cdt.make.core/specs.o .metadata/.plugins/org.eclipse.cdt.make.core/specs.c
I just to test the compiler flag I added the following function, and the compiler detects the unused variable, but not the unused function!
void MyUnusedFunction(void) { int i; printf("I do nothing\n"); }
Any ideas?
Because your function is not defined as static void it could be used in other files. Since the compiler looks at only one file at a time it has no way of knowing if this is the case.
Thanks, the fun of a different compiler.
