12453 Discussions
Convert Dot Multiply from C2H to ???
I have the following simple vector dot multiply as a C2H accelerator.
For some situations (but not all) regular NIOS running 50MHz on a 2C8 is fast enough running in code.
I want to implement this as something supported by Qsys and newer Quartus.
Options? Special instruction in NIOS? User component in Qsys? Something else?
I have constructed signal processing accelerators outside of NIOS using read and write masters, but would like to avoid that effort here.
Seems likely this function has been covered before.
// Multiply data vector with polyphase filter int DotMpy(int* __restrict__ r, int* __restrict__ p, alt_u16 PolySel) { # pragma altera_accelerate connect_variable DotMpy/r to sdram # pragma altera_accelerate connect_variable DotMpy/r to onchip_SRAM # pragma altera_accelerate connect_variable DotMpy/p to onchip_SRAM long long SumVal = 0; int k = 20; do { SumVal += (long long)*r++ * (long long)*p; if (PolySel&0x100) (p--); else (p++); } while (--k); return (int)(SumVal >> 16); }
