12600 Discussions
Convert dec to hex using nios ii
I was curious if there were a list of functions, in Nios ii using C, that convert decimal values to hex, binary etc... I am use to programming in Matlab so I am use to the quick and easy hex2dec converter. Thanks.
Nios or any other cpu always works with binary values. Other numeric bases makes sense only for formatted input/output.
In this case the common stdio printf/scanf functions can do what you are asking for:
printf("%d", v) : v in decimal format
printf("%x", v) : v in hex format
printf("%o", v) : v in octal format
I tend to avoid all the scanf() family of functions, they are very difficult to use safely.
One of the strtoul() family is generally better for converting ascii input strings.
do take note if the convertion that to hex 16 bit or 32 bit based hex value.
