12472 Discussions
Creating static library without bsp
I need to create a simple static library to be linked with my main NIOS-II application.
I don't want to have that library be dependent on BSP, because it is purely software logics.
Is there a built-in way to achieve this with NIOS II SBT eclipse?
I'm using NIOS-II SBT 12.0.
In menu, I think, you get New>library.
Nios II SBT is designed to be used with material boards. That is why BSP is needed : it matches hardware and software.
But you can create simple application without NIOS II.
Can you give an example of what you want to do ?
New>Library option requires BSP.
My intention is to build a NIOS II application which depends on some utilities which are compiled as static library. These utilities are not hardware based but pure software based. This is why I want it created without the BSP.
An example utility can be something that manages strings.
