Custom Flash is not supported in altera qsys 12.0, please let us know immediately, how to resolve this. we are using startix V FPGA
I'm only using Cyclone FPGAs, but I think you must use the tristate conduit bridge with the generic controller to use cfi.
yes, you can use your flash memory, i did it.
you must use 3 "components": Flash_generic_tristate_controller ^ | | tristate_conduit_pin_sharer ^ | | tristate conduit bridge It has been explained in an Altera PDF : look around Qsys and tristated component, be carfull of versions, make sure that you read for versions > 10.0 www.altera.com/literature/hb/qts/qsys_interconnect.pdf Unfortunately, you have to edit you custom Flash component http://www.altera.com/literature/ug/ug_embedded_ip.pdf 4. Common Flash Interface Controller Core When you edit your flash component, you must add by hand the lines in {I don't remember} Is memory device=1 Parameter=embeddedsw.configuration.hwClassnameDriverSupportList,embeddedsw.CMacro.SUPPORTS_FLASH_FILE_SYSTEM Value=altera_avalon_lan91c111:altera_avalon_cfi_flash,1 and in a place just below Parameter=embeddedsw.configuration.isMemoryDevice,embeddedsw.configuration.isPrintableDevice,embeddedsw.configuration.isNonVolatileStorage Value=1,0,1 Please have a look with legacy CFI Flash component already present. I spent 2 weeks to partially understand that and finally get my board work by "just working, don't touch ;-)" (no good work, no warranty) I post here MY file with absolutely NO WARRANTY EDIT : Make sure that your Qsys system is in your directory project (no subdirectory) : I posted on an ohter post for that inconvenient. Don't use space or "__" (double underscore) in your name, all lowercase (to avoid probable case sensitivity) EDIT 2 : For software (exactly BSP Board Support Package) That is not all :-P:-P:-P In Qsys-edit, you must tell that your component is a Flash by opting for the "good driver" in a drop down list. EDIT 3 : We like difficulties :p hope it can help you and if you succeed, make us aware.- Mark as New
If your cfi pins are not shared with other components, there is no need to use the tristate_conduit_pin_sharer.
In my system the cfi works well without.- Mark as New
Have been developing FPGA and NIOS-based SW for DE2-115 using USB blaster to load SOF and elf files for debugging.
Now want to permanently program FPGA and FLASH. Have been able to load POF into FPGA. Can execute NIOS SW from SDRAM. However, it fails to execute when I try to flash it. Following is the process I've used. But in Custom Flash is not supported in Altera Qsys 12.0 ??? i have tried for Flash_generic_tristate_controller ^ | | tristate_conduit_pin_sharer ^ | | tristate conduit bridge but it is not taken as a memory i have given the flowwing in bsp editor also Nios II cannot boot up 1. reset -> CFI flash 2. exception -> SDRAM 3. Linker setting: .bss .heap .rodata .rwdata .stack .txt => SDRAM- Mark as New
Dear http://www.alteraforum.com/forum/image.php?u=80420&dateline=1357065938 (http://www.alteraforum.com/forum/member.php?u=80420) friedrichv (http://www.alteraforum.com/forum/member.php?u=80420)
http://www.alteraforum.com/forum/images/statusicon/user-online.png pls give some valuable comments pls don't confuse me- Mark as New
Tnx mmTsuchi :)
sorry if I confused you:
You don't need to include the tristate_conduit_pin_sharer in your system if the the hardware connections to the CFI Flash are not shared with other chips in the system (which is the case for the DE115). You can connect the generic_tristate_controller directly to the tristate conduit bridge (tcs to tcm). I have build several systems that work this way. The CFI will work only if you set the right parameters (size, adress width, signal polarities etc.) Just look at the provided demo projects, you have to scroll down in the generic_tristate_controller window to see them all. There is also a right pane where you can choose presets. I have had no problems flashing the cfi, your configuration seems ok to me. Have a look at the output from the Nios2 flasher to see if it has included the boot loader.- Mark as New
OK, if Flash pins are not shared, "tristate conduit pin sharer" is not needed.
Flash presets (Quartus 12.0SP1) didn't make me happy ;-) Flash memory must be taken as memory in BSP In qsys-edit, flash memory generic .... component editor, check : (this is an example) in module_assignment :
embeddedsw.configuration.hwClassnameDriverSupportList = altera_avalon_lan91c111:altera_avalon_cfi_flash
embeddedsw.configuration.isMemoryDevice = 1
embeddedsw.CMacro.SIZE = 4194304 for my 4MB
embeddedsw.configuration.hwClassnameDriverSupportDefault = altera_avalon_cfi_flash
embeddedsw.memoryInfo.IS_FLASH = 1
embeddedsw.memoryInfo.FLASH_INSTALL_DIR = APP_DIR
in interface_assignment :
embeddedsw.configuration.isFlash = 1
embeddedsw.configuration.isNonVolatileStorage = 1
embeddedsw.configuration.isPrintableDevice =0
embeddedsw.CMacro.SETUP_VALUE = 65
embeddedsw.CMacro.WAIT_VALUE = 100
embeddedsw.CMacro.HOLD_VALUE = 30
After generating Qsys, you will be able to select "altera_avalon_cfi_flash" for flash in BSP editor. EDIT : Good Luck
--- Quote Start --- sorry if I confused you: You don't need to include the tristate_conduit_pin_sharer in your system if the the hardware connections to the CFI Flash are not shared with other chips in the system (which is the case for the DE115). You can connect the generic_tristate_controller directly to the tristate conduit bridge (tcs to tcm). I have build several systems that work this way. The CFI will work only if you set the right parameters (size, adress width, signal polarities etc.) Just look at the provided demo projects, you have to scroll down in the generic_tristate_controller window to see them all. There is also a right pane where you can choose presets. I have had no problems flashing the cfi, your configuration seems ok to me. Have a look at the output from the Nios2 flasher to see if it has included the boot loader. --- Quote End --- Hi, I have used the same but did't get exact pins can you share your .qsf file and .qar files (Qsys system) Regads asickrishna
