I am using an Altera Cyclone V SoC dev board.
I built a custom Linux platform using Yocto and I finally got everything working and in a state in which I could run my AOCL program... However my FPGA program now runs about 1000x slower than when I use a prebuilt image. I am getting the following error on boot and I am guessing that it is related to the poor performance:
hwclock: can't open '/dev/misc/rtc': No such file or directory
INIT: Entering runlevel: 5misc/rtc': No such file or directory
There are no rtc files on the board as far as I can tell (find / -name "*rtc*" returns nothing). Two questions then: - Any ideas why I am taking a 1000x performance hit using my custom Linux build?
- If my assumptions are correct in that the hwclock/rtc is the culprit, any ideas on how to rectify this? or add something to my Yocto build or device tree or something?
UPDATE:
I've modified my my Linux image and fixed the issue with the `rtc`, however this did not help the performance! Some interesting behaviour though, I launch my AOCL kernel multiple times, the first launch has execution times that appear to be in the ideal range of `0 < t < 1000ms`, and all subsequent launches report times of almost exactly `t=1000ms`. This leads me to believe that there is a `1s` clock somewhere that is responsible for the performance hit. My thinking is the first kernel launch could fall anywhere in the clock cycle, and returns on the next edge, hence `0 < t < 1000`, whereas subsequent launches will occur on the clock edge, hence `t=1000ms`. I also tested the `vector_add` example on my custom image and the prebuilt image (16.1); with my custom image it reports variable kernel time on the order of ` 0 < t < 1000ms` like I was seeing with my kernel. Using the prebuilt image I get consistent performance around `t=8.5ms`. I would love to hear your thoughts and suggestions! :)
