12453 Discussions
Custom QuadSPI Controller and NIOS2 Initialization
trigerion
I am currently developing a custom QuadSPI Avalon Memory Mapped Component for a MAX10 FPGA as we use a not support QSPI flash in our current design.
I am struggling what to add to the tcl file in order to be able to generate the hex file with mem_init_generate script with eclipse.
I added the following lines
# # module assignments # set_module_assignment embeddedsw.memoryInfo.GENERATE_DAT_SYM 1 set_module_assignment embeddedsw.memoryInfo.GENERATE_HEX 1 set_module_assignment embeddedsw.memoryInfo.IS_FLASH 1 set_module_assignment embeddedsw.memoryInfo.MEM_INIT_DATA_WIDTH 8 set_module_assignment embeddedsw.memoryInfo.WIDTH 32
but the mem_init.mk looks like this
# Memory: qspi_max1000_1 MEM_1 := max1000_qspi $(MEM_1)_NAME := qspi_max1000_1 MEM_INIT_INSTALL_FILES += $(MEM_INIT_INSTALL_DIR)/$(MEM_1).hex $(MEM_1)_START := 0x02000000 $(MEM_1)_END := 0x03ffffff $(MEM_1)_SPAN := 0x02000000 $(MEM_1)_HIERARCHICAL_PATH := qspi_max1000_1 $(MEM_1)_WIDTH := 32 $(MEM_1)_HEX_DATA_WIDTH := 8 $(MEM_1)_ENDIANNESS := --little-endian-mem $(MEM_1)_CREATE_LANES := 0 $(MEM_1)_CFI_FLAGS := --base=$($(MEM_1)_START) --end=$($(MEM_1)_END) --reset=$(RESET_ADDRESS) $(MEM_1)_BOOT_LOADER_FLAG := --boot="$(BOOT_LOADER_CFI)"
instead of
# Memory: qspi_max1000_1 MEM_1 := max1000_qspi $(MEM_1)_NAME := qspi_max1000_1 HEX_FILES += $(MEM_INIT_DIR)/$(MEM_1).hex MEM_INIT_INSTALL_FILES += $(MEM_INIT_INSTALL_DIR)/$(MEM_1).hex $(MEM_1)_START := 0x02000000 $(MEM_1)_END := 0x03ffffff $(MEM_1)_SPAN := 0x02000000 $(MEM_1)_HIERARCHICAL_PATH := qspi_max1000_1 $(MEM_1)_WIDTH := 32 $(MEM_1)_HEX_DATA_WIDTH := 8 $(MEM_1)_ENDIANNESS := --little-endian-mem $(MEM_1)_CREATE_LANES := 0 $(MEM_1)_CFI_FLAGS := --base=$($(MEM_1)_START) --end=$($(MEM_1)_END) --reset=$(RESET_ADDRESS) $(MEM_1)_BOOT_LOADER_FLAG := --boot="$(BOOT_LOADER_CFI)"   .PHONY: qspi_max1000_1 qspi_max1000_1: check_elf_exists $(MEM_INIT_DIR)/$(MEM_1).hex
As the 'HEX_FILES +=' and '.PHONY: qspi_max1000_1
qspi_max1000_1: check_elf_exists $(MEM_INIT_DIR)/$(MEM_1).hex' is missing, I do not get the hex file when calling mem_init_generate.
Can somebody help me and suggest what I am doing wrong or what I should add the the tcl file?
Thank you very much.
