Hi All,
I've created a custom hardware component that successfully integrates with Qsys and can be attached to a NIOS II/e core. I'm now trying to persuade the Eclipse software build tools to include the component's header file within a BSP (The header just define basic IO macros). The component is very simple, so doesn't really need a full HAL driver, but for completeness, I'd like the header file (and perhaps a basic c library) automatically imported within the BSP. Here is my _sw.tcl file:# Create a new driver
create_driver push_buttons_driver
# Associate it with hardware
set_sw_property hw_class_name PushButtons
# The version of this driver
set_sw_property version 1.0
# Location in generated BSP that sources will be copied into
set_sw_property bsp_subdirectory drivers
# Source file listings
add_sw_property include_source inc/pushButtons_regs.h
# This driver supports LWHAL (OS) types
add_sw_property supported_bsp_type HAL
add_sw_property supported_bsp_type UCOSII
add_sw_property supported_bsp_type LWHAL
The directory structure is simple: PushButtons
- inc
- pushButtons_regs.h
- PushButtons.vhdl
- PushButtons_hw.tcl
- PushButtons_sw.tcl (as listed above)
If I create a new BSP the pushButton_regs.h file does not get copied into the Eclipse project. So, two questions: - Have I missed some obvious step/file in order to get this working? - At what point is the PushButtons_sw.tcl file scanned to check for changes and hopefully copy component specific files into a BSP project? I'd hoped this would happen when 'Generate BSP' is selected from within Eclipse. All component files are zipped up and attached below. Many thanks Andy
