I found what appears to be a bug in the example_design.c file, but didn't see a means to report it directly. So, I'm posting it here.
example_design.c:233 for(int i=0; i<test_set->hardware_instances; i++)
test_set->bg_counters = 0;
should be for(int i=0; i<test_set->hardware_instances; i++)
(see https://www.altera.com/support/support-resources/design-examples/soc/fpga-to-hps-bridges-design-example.html)
Thanks for notifying the bug, let us check/workaround it. We will get back to you on this as soon as possible. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
